Devon Tile Doctor
Servicing the county of Devon, Harry is your local specialist for tile cleaning, stone cleaning, grout cleaning and tile, stone and grout sealing covering the restoration of all types of stone and tile.
Nottinghamshire Tile Doctor
Steve is your local specialist for tile cleaning, stone cleaning, grout cleaning and tile, stone and grout sealing covering the restoration of all types of stone and tiled flooring.
Fireplace Tile Cleaning
Help with Tile and Stone  >  Fireplace Cleaning
Fireplace Cleaning
The advice below will help you deep clean and maintain stone or tiled Fireplace surrounds and hearths to a good standard and protect them from soot and other staining going forward.
Fireplace Cleaning
Limestone Tile Apply Tile Doctor Oxy-Gel Tile & Grout cleaner with a brush to the surround, hearth and wall plate, leave to dwell for 25 minutes then clean with soft and hard brushes depending of level of staining.
Limstone Tile ROUGH/RIVEN FIREPLACE: If further cleaning is required on rough/riven stone fireplaces repeat the above process using harder brushes until dirt has been removed and increase Oxy-Gel dwell time.
Limstone Tile SMOOTH MATT FINISH: If further cleaning is required on smooth or Matt finish stone fireplaces try using Tile Doctor Diamond Blocks, starting with a green 60 grit , ( spray water on the surface to clean with each block ) then use the 100 black Grit, followed by the red 200 and yellow 400 grit, and again rinsed off with water, the Diamond blocks are very good at working into edges and corners where dirt and muck can lay in place, make sure you cover the whole surface to be cleaned with each block with special emphasis on using the green block first as this will remove scratches’, trapped dirt, soot etc.
Limstone Tile Rinse off with water and soft sponges to remove any cleaning solution and soil, then extract moisture using a wet vacuum, allow to dry for 12 hours or more before sealing.
Limstone Tile For a natural look finish use a single coat of Tile Doctor Ultra-Seal which works really well on light coloured stone; alternately use Tile Doctor Colour Grow to enhance the look of dark coloured stone. Both are matt sealers and suitable for use on Wood, Gas or Coal burning fireplace’s and stoves.
Limstone Tile Most sealers break down after 2-3 years (depending on usage and cleaning products used) so for regular cleaning use a sealer friendly cleaning product such as Neutral Tile Cleaner which has been especially formulated for the regular cleaning of Sealed Stone and Tile surfaces keeping them fresh with a pleasant mint scent.
POLISHED STONE FIREPLACES
Limestone Tile Don’t attempt to reseal these types of tiles yourself. Seek professional help as you will need experience, machinery and the correct products and procedure in order to take out scratches, marks and re-polish. Your local Tile Doctor would be happy to advise you on this, you contact them via the: Tile Doctor Home Service Page.
For many examples of Limestone cleaning and sealing activities carried out by UK Tile Doctors please visit http://fireplace.tilecleaning.co.uk
Recommend Fireplace Cleaning Products
Burr Line Sponge (Pack of 10)
Effortlessly clean away stubborn marks from tiles with our multi-surface cleaning sponge. It quickly removes polishing residues, stains, and everyday scuffs from most surfaces — no chemicals required. Simply wet and wipe for instant results.
700050
£5.16
Diamond Hand Burnishing Block Green 60 Grit
Green 60 grit diamond burnishing block ideal for use in restricted spaces. Use only Water.
700046
£27.00
Diamond Hand Burnishing Block Black 120 Grit
Black 120 grit diamond burnishing block ideal for use in restricted spaces. Use only Water.
700041
£22.75
Diamond Hand Burnishing Block Yellow 400 Grit
Yellow 400 grit diamond burnishing block ideal for use in restricted spaces. Use only Water.
700044
£22.25
Diamond Hand Burnishing Block Red 200 Grit
Red 200 grit diamond burnishing block ideal for use in restricted spaces. Use only Water.
700042
£22.25
761500
761000
Diamond Hand Burnishing Block  Set ( Green,Black,Red, Yellow )
Set of four hand use burnishing blocks in 60, 100, 200 and 400 grit blocks ideal for use in restricted spaces. Use only Water.
700040
£68.30
740246
750246
Detailed advice and further information for cleaning and maintaining  stone or tiled fireplaces including surrounds and hearths including Limestone, Marble and Sandstone fireplaces.
