Merseyside Tile Doctor
Servicing Liverpool and the Merseyside area Andrew is your local specialist for tile cleaning, stone cleaning, grout cleaning and tile, stone and grout sealing covering the restoration of all types of stone and tile.
 6 Inch  800 Grit Medium No.2 Burnishing Pad
Initial polish, only use with water.
Tile Doctor Grout Care | Grout Cleaning, Grout Recolouring and Grout Sealing tips
Grout Cleaning Advice
The top layer of grout is porous and, as a result, they easily absorb grease, dirt and lime scale. Spillages such as wine, lemonades or greasy substances will cause marks and patches in the joints in the floor. Grout between wall-tiles, particularly in damp areas like bathrooms, will become dirty and unattractive as a result of Mould, Mildew and Limescale.
Mould is one of the most unsightly problems, which usually starts off in the wettest area of the room, this could be the bottom of the shower or bath, then starts to spread and if left unchecked could cover a large area of the wall. Fortunately Tile Doctor have a product called Duo-Clean that can deal with this.
Grout Haze where a thin layer of grout has been left to set on the surface of the tile is a common issue that can be removed using Tile Doctor Grout Clean-up or Acid Gel.
Discolouration of grout joints in bath or shower areas due to continued use of acid formulated shampoos and soaps. This causes yellow orange and pink stains to the grout over even a short period of time. Whilst Grout Joints can be cleaned, badly stained grouts may need to be re-coloured.
Protecting your grout in advance with a sealer will prevent most of these issues and although relatively unknown in the UK, protection awareness is growing. Sealing forms an invisible barrier between the grout and the surface, this will then protect your investment for years to come.
Further Reading: For many more examples and photographs of of Grout maintenance activities carried out by UK Tile Doctors please visit https://grout.tilecleaning.co.uk/
Recommend Products for Maintaining Grout
Grout Brush and Wheel set 4mm and 8mm
Grout Colourant Grout Brush and Wheel set (4mm and 8mm), fits Grout Colourant bottle for easy deployment of grout colours.
£9.99
Green Handheld Scrubbing Brush
Handheld scrubbing brush with ergonomic design for the scrubbing of tile and grout.
£10.99
Washable Extendable Grout Brush
Washable grout brush use by hand or attach to a standard pole via the universal screw attachment for best results. The unique convex head design will fit into any size grout line between 2mm up-to 25mm.
£10.99
Grout Colourant Pre-Treat Cleaner 750ml ( with trigger spray )
Effective ready-to-use cleaner designed to lightly etch and also remove dirt, soil, soap scum and hard water deposits from grout joints. Use before applying Grout Colourant to prepare the grout joints for a superior bond with the Grout Colourant.
£13.12
Tile Doctor Duo Clean 1 litre
£10.80
Wall Tile and Grout Sealer Aerosol Spray 500ml
Wall Tile & Grout Sealer Aerosol Spray. Quick and efficient effective sealer, fully waterproof, easy to apply quick drying spray-on sealer for wall tile and grout. Adds long lasting protection against water, dirt, grease, mould and limescale.
Grout Colourant Kit
All-in-one Grout Colourant kit to prep, recolour and seal your grout joints. Kit contains 237ml Grout Colorant, 750ml Grout Colorant Pre-Treat Cleaner, grout brush and scrub pad.
£35.00
Tile Doctor Stone Soap 1 Litre
£14.40
Grout Colourant
Easy-to use waterborne epoxy that recolours, seals and rejuvenates existing grout joints. Recommended for use on sanded, unsanded and epoxy grout joints.
£26.80
£15.23
Specialist advice and products for maintaining, cleaning, sealing and even recolouring grout.
