Diamond Hand Burnishing Block Black 120 Grit
Black 120 grit diamond burnishing block ideal for use in restricted spaces. Use only Water.
£22.75
Tile Doctor Aqua-Pro ( with trigger spray )
£11.88
Tile Doctor | Tile Grout Cleaning and Colouring
Tile Doctor Products  >  Grout Colouring
Grout Colouring
We sell two products for changing the colour of grout: Wall grout pens are a quick inexpensive way of touching up the look of grout that has become discoloured and for a long lasting/permanent change of colour use one of our Epoxy Grout Colouring products available in ten popular colours.
Grout Brush and Wheel set 4mm and 8mm
Grout Colourant Grout Brush and Wheel set (4mm and 8mm), fits Grout Colourant bottle for easy deployment of grout colours.
£9.99
Grout Colourant Pre-Treat Cleaner 750ml ( with trigger spray )
Effective ready-to-use cleaner designed to lightly etch and also remove dirt, soil, soap scum and hard water deposits from grout joints. Use before applying Grout Colourant to prepare the grout joints for a superior bond with the Grout Colourant.
Grout Colourant Kit
All-in-one Grout Colourant kit to prep, recolour and seal your grout joints. Kit contains 237ml Grout Colorant, 750ml Grout Colorant Pre-Treat Cleaner, grout brush and scrub pad.
£35.00
Grout Colourant
Easy-to use waterborne epoxy that recolours, seals and rejuvenates existing grout joints. Recommended for use on sanded, unsanded and epoxy grout joints.
£26.80
Tile Doctor UK - Information on changing the colour of your Tile Grout -  Tile Doctor Specalising in Granite tile and grout cleaning, cleaning tile grout, tile grout cleaner, tile grout cleaning methods, grout sealer
