Trevor is your local specialist for tile cleaning, stone cleaning, grout cleaning and tile, stone and grout sealing covering the restoration of all types of stone and tiled flooring.
Mick is your local specialist for tile cleaning, stone cleaning, grout cleaning and tile, stone and grout sealing covering the restoration of all types of stone and tiled flooring.
Flagstone Tile Cleaning
![]() Flagstone is a general term used to describe large blocks of stone which are normally made from Sandstone or Slate however its not unusual to get Marble and Limestone Flags as well, especially in old Churches and Abbeys. Like any natural stone it needs to be sealed to protect it and bring out its beauty and colour. A lot of Flagstone floors found in 200+ year old cottages is termed as Thick Flags and are a dense form of Sandstone, so there can be some confusion about the term Flagstone in the retail sector, but if you ask any Geologist worth his salt he will tell you that Thick Flags and Sandstone are a different entity although similar in composition in many ways. Flagstone Tile MaintenanceGiven the different types of stone that Flagstones can be made from we recommend you visit our specific information pages for general maintenance information.
Flagsone Restoration with MillingUsually when we are asked to clean these old flagstone floors, whether it be true Thick Flagstone or a mixture of weathered Slate or Sandstone, they are often in a very poor state of repair and we have to offer something that is a bit different to get the stone back to looking anywhere near what it should look like. As a result we have developed a system called Milling which uses a heavy weighted buffing machine fitted with a very coarse 50-grit segmented diamond pad running at slow speed to cut the stone down a few millimetres. This process works in the same way a carpenter would treat damaged wood, i.e. he wood sand it down and then polish it with an oil, well we do the same using various grits of diamond pads and then when done apply a sealer. Flagstone Milling PadsTo mill the floor start with the very coarse 50-grit pad first, then apply the 100-grit and 200-grit pad to restore the surface, use water to lubricate during the milling process and rinse the floor with water to remove the slurry between each pad.
6 Inch 50-grit very coarse diamond milling Pad for resurfacing stone floors.
£27.00
17 Inch 50-grit very coarse diamond milling Pad for resurfacing stone floors.
£65.50
£79.44
£17.52
17 Inch Coarse 200-grit diamond Milling Pad for resurfacing stone floors after milling. Can also be used for cleaning Victorian floor tiles.
£65.50
17 Inch 100 Grit very coarse diamond milling Pad for resurfacing rough stone floors after milling. Can also be used for cleaning Victorian floor tiles.
£65.50
£22.56
