London South East Tile Doctor
With a background in tiling Jason covers Southeast London and is your local specialist for tile cleaning, stone cleaning, grout cleaning and tile, stone and grout sealing covering the restoration of all types of stone and tiled flooring.
Tile Doctor | Milling pads for the Regeneration of Stone
Tile Doctor Products  >  Stone Milling
Stone Milling
Milling cuts deeper into the stone or tile than Burnishing, allowing for the removal of a heavily worn layer and revealing new stone underneath. These pads come in different sizes, types and grits, designed for the complete regeneration of stone surfaces and achieve results that go far beyond polishing.
  • Coarse Diamond encrusted multi-purpose pads for the removal of scratches and deeper cleaning.
  • DRB Diamond pads are for use on Rough and Flagged stone to make it smoother and reduce lippage between badly laid tiles.
  • Flexi Segment Pads are for the use on Honed and Polished stone to reduce lippage between badly laid tiles and cut the stone back ready for polishing with finer grade burnishing pads.
  • Start with the lowest grit pad fitted to a weighted buffing machine to ensure maximum contact with the stone surface. Run the pad evenly over each part of the stone floor at least three passes have been performed.
  • Use lots of water to lubricate the process and keep dust down to a minimum.
  • Flexi Segment and DRB Pads can also be used to smooth rough stone and reduce and level the surface of a stone floor, ideal for stone floors where the tiles have not been laid evenly and have lippage issues.
17 Inch  Burr Line Buffing Pad
Effortlessly clean away stubborn marks from tiles with our multi-surface 17-inch cleaning pad, its especially useful for removing remants from burnishing pads. No chemicals required, simply apply to the floor with water.
£39.00
Burr Line Sponge (Pack of 10)
Effortlessly clean away stubborn marks from tiles with our multi-surface cleaning sponge. It quickly removes polishing residues, stains, and everyday scuffs from most surfaces — no chemicals required. Simply wet and wipe for instant results.
£5.16
6 inch 1500 grit Diamond Floor Pad with Flexi Segment
£60.50
Flexi Segment  6 Inch  800 grit Diamond Floor Pad
6 inch 800 grit Diamond Floor Pad with Flexi Segment
£60.50
Flexi Segment 17 Inch 1500 grit Diamond Floor Pad
17 inch 1500 grit Diamond Floor Pad with Flexi Segment
£150.00
Flexi Segment 17 Inch  800 grit Diamond Floor Pad
17 inch 800 grit Diamond Floor Pad with Flexi Segment
£150.00
 6 Inch   50 Grit Very Coarse Milling Pad
6 Inch 50-grit very coarse diamond milling Pad for resurfacing stone floors.
£27.00
Flexi Segment 17 Inch  400 grit Diamond Floor Pad
17 inch 400 grit Diamond Floor Pad with Flexi Segment
£150.00
Flexi Segment 17 Inch  200 grit Diamond Floor Pad
17 inch 200 grit Diamond Floor Pad with Flexi Segment
£150.00
Flexi Segment 17 Inch  100 grit Diamond Floor Pad
17 inch 100 grit Diamond Floor Pad with Flexi Segment
£150.00
Flexi Segment 17 Inch   50 grit Diamond Floor Pad
17 inch 50 grit Diamond Floor Pad with Flexi Segment
£150.00
Flexi Segment  6 Inch  400 grit Diamond Floor Pad
6 inch 400 grit Diamond Floor Pad with Flexi Segment
£60.50
Flexi Segment  6 Inch  200 grit Diamond Floor Pad
6 inch 200 grit Diamond Floor Pad with Flexi Segment
£60.50
Flexi Segment  6 Inch  100 grit Diamond Floor Pad
6 inch 100 grit Diamond Floor Pad with Flexi Segment
£60.50
Flexi Segment  6 Inch   50 grit Diamond Floor Pad
6 inch 50 grit Diamond Floor Pad with Flexi Segment
£60.50
17 Inch  50 Grit Very Coarse Milling Pad
17 Inch 50-grit very coarse diamond milling Pad for resurfacing stone floors.
£65.50
Diamond Hand Burnishing Block Green 60 Grit
Green 60 grit diamond burnishing block ideal for use in restricted spaces. Use only Water.
£27.00
Diamond Hand Burnishing Block Black 120 Grit
Black 120 grit diamond burnishing block ideal for use in restricted spaces. Use only Water.
£22.75
Diamond Hand Burnishing Block Yellow 400 Grit
Yellow 400 grit diamond burnishing block ideal for use in restricted spaces. Use only Water.
£22.25
Diamond Hand Burnishing Block Red 200 Grit
Red 200 grit diamond burnishing block ideal for use in restricted spaces. Use only Water.
£22.25
DRB 17 Inch 200 Grit Coarse Diamond Milling Pad with Segments
Coarse 17 inch 200 grit milling pad with DRB (Diamond Resin Block) segments for milling rough or uneven stone floors and resolving lippage issues.
£142.50
 6 Inch  100 Grit Very Coarse  Stone Resurfacing Pad
6 Inch 100 Grit Very Coarse Grey Stone Resurfacing Pad
£27.00
 6 Inch  200 Grit Coarse Stone Resurfacing Pad
6 Inch 200 Grit Coarse Blue Stone Resurfacing Pad
£27.00
17 Inch 200 Grit Coarse Milling Pad
17 Inch Coarse 200-grit diamond Milling Pad for resurfacing stone floors after milling. Can also be used for cleaning Victorian floor tiles.
£65.50
17 Inch 100 Grit Very Coarse Milling Pad
17 Inch 100 Grit very coarse diamond milling Pad for resurfacing rough stone floors after milling. Can also be used for cleaning Victorian floor tiles.
£65.50
Diamond Hand Burnishing Block  Set ( Green,Black,Red, Yellow )
Set of four hand use burnishing blocks in 60, 100, 200 and 400 grit blocks ideal for use in restricted spaces. Use only Water.
£68.30
Regeneration of Stone Surfaces with the use of Coarse Diamond Encrused pads
