17 Inch Mega 120-Grit Carborundum Silicone Carbide Brush
17 Inch Mega 120-Grit Carborundum Silicone Carbide Brush- Call for details - Please note these pads need retrofitting.
£195.00
 6 Inch Black Buffer Pads
6 Inch Buffer Pad Black
£5.25
Tile Doctor | Professional Tile and Stone Buffing shop
Tile Doctor Products  >  Tile Buffing
Tile Buffing
Sixteen inch Buffing pads for Cleaning, Buffing and Polishing tiled floors. To be used with a standard rotary floor machine.
17 Inch  Burr Line Buffing Pad
Effortlessly clean away stubborn marks from tiles with our multi-surface 17-inch cleaning pad, its especially useful for removing remants from burnishing pads. No chemicals required, simply apply to the floor with water.
£39.00
Burr Line Sponge (Pack of 10)
Effortlessly clean away stubborn marks from tiles with our multi-surface cleaning sponge. It quickly removes polishing residues, stains, and everyday scuffs from most surfaces — no chemicals required. Simply wet and wipe for instant results.
£5.16
Tile Doctor Stone Gel 1kg Tub
Stone Gel - For Polishing Basalt, Granite & Quartz Surfaces
£59.00
17 Inch Buffing Pad Tan
Tan Buffing pad 17" (44cm), dry cleaning, polishing and maintenance cleaning, use with Neutral Cleaner after floor is washed and dried to give that finishing touch to the floor.
£5.25
 6 inch White Buffer Pads
6 inch White Buffer pads for use with a hand buffing machine to lightly polish and clean polished surfaces without causing scratches.
£5.25
17 inch Buffing Pad White
White Buffing pad 17" (44cm), for light polishing and general regular maintenance cleaning of polished stone surfaces. Can be used in conjunction with Neutral Tile Cleaner or Stone Soap.
17 inch Buffing Pad Black
17 inch Buffing Pad Red
Red Buffing pad 17" (44cm), dry cleaning, polishing and maintenance cleaning, use with Neutral Cleaner after floor is washed and dried to give that finishing touch to the floor.
17 inch Buffing Pad Green
Green Buffing pad, pad 17" (44cm), for medium duty cleaning, can be used on all types of floor (except polished stone), use with Tile Doctor Pro-Clean to remove general dirt and grime.
Tile Doctor Shine Powder 1kg Tub
Tile Doctor High Shine Crystallising Powder adds a Very High Shine to Limestone, Marble, Polished Concrete, Terrazzo and Travertine.
Cleaning, Burnishing and Polishing accessories for Stone and Tile Cleaning
