£40.56
Dorset Tile Doctor
Steve covers the county of Dorset and is your local specialist for tile cleaning, stone cleaning, grout cleaning and tile, stone and grout sealing covering the restoration of all types of stone and tiled flooring.
Tile Doctor | Stone, Tile and Grout cleaning product shop
Tile Doctor Products  >  Cleaning Tile & Stone
Tile Doctor recommended products for effective Tile, Stone and Grout Cleaning.
Customers should be aware that most supermarket tile cleaners are acidic in nature and sold for the cleaning of Ceramic and Porcelain tiles, for Sealed or Stone surfaces a PH neutral product should be used.
17 Inch  Burr Line Buffing Pad
Effortlessly clean away stubborn marks from tiles with our multi-surface 17-inch cleaning pad, its especially useful for removing remants from burnishing pads. No chemicals required, simply apply to the floor with water.
£39.00
Burr Line Sponge (Pack of 10)
Effortlessly clean away stubborn marks from tiles with our multi-surface cleaning sponge. It quickly removes polishing residues, stains, and everyday scuffs from most surfaces — no chemicals required. Simply wet and wipe for instant results.
£5.16
Green Handheld Scrubbing Brush
Handheld scrubbing brush with ergonomic design for the scrubbing of tile and grout.
£10.99
Washable Extendable Grout Brush
Washable grout brush use by hand or attach to a standard pole via the universal screw attachment for best results. The unique convex head design will fit into any size grout line between 2mm up-to 25mm.
£10.99
Tile Doctor Duo Clean 1 litre
£11.40
£79.44
£17.52
Tile Doctor Pro-Clean 5 Litre
£54.24
Tile Doctor Stone Soap 1 Litre
£15.12
17 inch Buffing Pad White
White Buffing pad 17" (44cm), for light polishing and general regular maintenance cleaning of polished stone surfaces. Can be used in conjunction with Neutral Tile Cleaner or Stone Soap.
17 inch Buffing Pad Black
Tile Doctor Neutral Tile Cleaner 5 Litre
£53.64
Tile Doctor Stone Patina Spray 500ml
A spray-and-buff cleaner that is designed to enhance the natural beauty and lustre of polished stone as it cleans. Regular use helps protect factory polish.
£11.88
£15.84
£14.52
Tile Doctor Aqua-Pro – pH Neutral Tile & Grout Cleaner 500ml
£11.88
Tile Doctor recommended products and methods for effective Tile, Stone and Grout Cleaning.
