Oxfordshire Tile Doctor
Barry and his team are your local specialists for tile cleaning, stone cleaning, grout cleaning and tile, stone and grout sealing covering the restoration of all types of stone and tiled flooring.
Hampshire Tile Doctor
Servicing the county of Hampshire Charles and his team are your local specialists for tile cleaning, stone cleaning, grout cleaning and tile, stone and grout sealing covering the restoration of all types of stone and tile.
Tile Doctor Product Shop
Tile Doctor Products
Tile Doctor has the largest network of Tile, Stone and Grout specialists in the UK who maintain hundreds of floors each month with Tile Doctor products. Not only does this give you the assurance that our products are fully tried and tested, we actively encourage feedback from our Tile Doctors and customers to enable us to constantly update our range and the advice we give.
If you are unsure about which products and methods you will need to maintain your floor do get in touch before purchasing, alternatively why not ask one of our local specialists to pop round to give you personal advice and a free quote.
Sub Categories
Cleaning Tile & Stone
Tile Doctor recommended products and methods for effective Tile, Stone and Grout Cleaning. Ideal for tile, stone and grout that has been sealed and can be damaged by acidic cleaning products.
Stone Burnishing
Stone Burnishing
Designed to restore the appearance of polished stone walls and floors burnishing pads are made with industrial diamonds and available in different sizes and grits.
Grout Colouring
Grout Colouring
We sell two products for Grout Colouring; the wall grout pens are a quick inexpensive way of touching up the look of grout and the Epoxy Grout Colouring products and for a permanent change of colour.
Stone Milling
Stone Milling
Very coarse diamond encrusted pads in different sizes and grits designed for the complete re-generation of stone surfaces that are beyond polishing.
Problem Solvers
Problem Solvers
A range of specialist Tile, Stone and Grout products designed to deal with common installation and maintenance issues. If you have a problem with your Tile, Stone or Grout Tile Doctor will have the solution.
Tile Buffing
Tile Buffing
Sixteen inch (41cm) buffing pads for cleaning, buffing and polishing tiled stone floors. All pads fit standard rotary floor buffing machines.
Stone and Tile Sealers
Tile Doctor recommended products for Stone and Grout Sealing to provide long lasting protection to Tile, Stone and Grout.
Tools
Tools
Cleaning tools category containing professional Cleaning Tools used in the maintenance of tile, stone and grout.
Tile Doctor Recommended products for the maintenance of Tile, Stone and Grout
