Servicing the county of Devon, Harry is your local specialist for tile cleaning, stone cleaning, grout cleaning and tile, stone and grout sealing covering the restoration of all types of stone and tile.
Patio and Driveway Cleaning
![]() Patio Cleaning covers a whole range of materials from precast concrete, all types of rough, textured or smooth honed stone to Porcelain and Victorian Tiled paths, as such you may get conflicting advice from other companies and people who either have very little experience in how to clean these types of Stone and tiles or they are using a wide brush to clean them all. If your not sure what type of material you have a photograph of your patio to to info@TileDoctor.co.uk along with approximate measurements and we will get back to you with the correct advice. Tile Doctor has published detailed maintenance information for all tile and stone so if you know what material you patio is made from then I would recommend you refer to those pages directly as they cover the most applicable techniques. The only exception being the choice of sealer as not all sealers can cope with the low temperatures in the UK. Patio Power WashingOur first thought when cleaning patios is to use a Pressure Washer which are an ideal tool for removing debris and cutting through soiling. These machines can be very powerful however so we recommend testing the machine in an inconspicuous area first. This will allow you to adjust the spray of water from a thin to wide fan and work out the best setting to avoid making lance marks or knocking out the grouting/mortar during use. Some machines include a "Spinning Attachment" which are very effective at cleaning patios and well worth the extra money.
Treating Heavy Soiling, Stubborn Stains such as BlackspotWe recommend using a product called Patio & Brick Driveway Cleaner, which is a powerful outdoor cleaning solution formulated for use by professionals. It will power through patio blackspots, lichen, moss, and stains and works on a wide range of outdoor surfaces to lift and clean deep seated dirt. This is a very strong product so make sure to follow the instructions on the back of the bottle and wear appropriate protection.
NB.. This product is not recommended for use on polished natural stone. ![]() ![]() English Sandstone Paving Cleaned with Tile Doctor Patio & Brick Driveway Cleaner
Black Limestone IssuesWhen it comes to external stone Black Limestone deserves a special mention. Its a very attractive stone that can be sourced very cheaply for as little as £20m2 or less. Having said that we don't recommend this stone for external use and buyers need to be wary as its not an easy stone to maintain due to Limestone being being very sensitive to acids. Use of brick acids and harsh chemicals on this stone can quite literally bleach the black oils in the stone and damage the surface leaving it looking grey. Strong power washing and bad weather can also degrade the appearance of the stone. ![]() ![]() Black Limestone Patio Ruined with Brick Acid in Highclere Village
Sealing, To seal or not to seal ?Outdoor stone doesn't require a seal, in nature it is not sealed, it looks great when it wet and a bit dull when its dry, if you power wash in the spring and again in summer this is all you have to do to it, no need for any chemicals if there is no sealer present.
Sealing Products Recommended for External use
Please note: Ceramic and Porcelain Tiles generally don't require sealing but the grout will benefit from an application of sealer. Therefore we recommend Tile Doctor Ultra Seal for use along the grout lines. This is best applied with a pipette to save mess or it can be brushed on but if using this method make sure to polish off any excess from the adjacent tile or stone using a clean cloth. For many examples of Patio and Driveway cleaning activities carried out by UK Tile Doctors please visit https://patio.tilecleaning.co.uk. Recommended Products
741000
745246
761500
761000
752346
£141.57
755000
£52.40
740246
750946
750246
