Coarse Burnishing pad for the removal of sealers and resurfacing of scratched surfaces, use only with water.
£50.00
Tile Doctor Vinyl Strip is an effective heavy duty floor polish stripper that quickly removes polish and films and coatings from vinyl floors. Its biodegradable, phosphate free and leaves a pleasant floral fragrance.
£41.00
Granite Tile Cleaning
![]() Granite is an Igneous Rock and makes for a great counter top Stone as it's a very good quality product, hard to mark, impervious to almost all chemicals and almost always comes with a highly polished finish, the exception being Flamed Granite which is a lot rougher. Granite Stone Maintenance
Polished GraniteIf you have the use of a 150 RPM (or slightly higher) buffing machine restore the honed finish by burnishing with a set of diamond burnishing pads. These pads remove old sealers and ground in dirt and restore the polished appearance. Click here for instructions and ordering.
Sealing Polished GraniteSeal the Granite (internal or external) with single coat of Tile Doctor X-Tra Seal. X-Tra Seal works especially well on dark stone where an oil-based sealer can really make the colours pop. Polish in well and off the stone with White Cotton Sealing cloths, after 5 minutes of it being applied.
![]() Black Granite Floor Tiles Polished with Stone Gel Recommended Products for Granite Tile MaintenanceWhen using our products please take time to familiarise yourself with the directions on the back of the bottle first.
Bleacked cotton sealing cloths (pack of 10), ideal for applying sealers to tiles.
£9.90
£93.24
White Buffing pad 17" (44cm), for light polishing and general regular maintenance cleaning of polished stone surfaces. Can be used in conjunction with Neutral Tile Cleaner or Stone Soap.
A spray-and-buff cleaner that is designed to enhance the natural beauty and lustre of polished stone as it cleans. Regular use helps protect factory polish.
£11.88
£15.84
£14.52
£37.92
