17 Inch Mega 120-Grit Carborundum Silicone Carbide Brush
17 Inch Mega 120-Grit Carborundum Silicone Carbide Brush- Call for details - Please note these pads need retrofitting.
£195.00
Travertine Tile Cleaning Information
Help with Tile and Stone  >  Travertine Tile Cleaning
Travertine tile is a natural stone material that has unique features and colouring that no other stone can offer. The distinctive design and natural patterns found within Travertine make it very popular as a flooring material and is often used as bathroom wall tiles and table tops. Travertine's durability makes it ideal for commercial and residential installations and it is often used externally.
Floor Tile Cleaning
Travertine TileIf you have the use of a 150 RPM (or slightly higher) buffing machine restore the honed finish by burnishing with a set of diamond burnishing pads. These pads remove old sealers and ground in dirt and restore the polished appearance. Click here for instructions and ordering.
When fully polished protect the stone by applying a sealer as per instructions below.
Set of Diamong Stone Burnishing Pads Please Note we also sell coarser 50, 100 and 200-grit Milling Pads in 6 and 17 inch sizes to be used where the stone requires a much deeper clean.
Cleaning Travertine Floor Tiles in Havant - photo courtesy of the Hampshire Tile Doctor
Limstone Tile Alternatively spray undiluted Tile Doctor Remove and Go onto the stone (use as directed), leave to dwell for ten to fifteen minutes (if necessary add more product to prevent it drying out) then agitate with a scrub brush or a black buffing pad fitted to a buffing machine.  Add water as you go to lubricate the process and then use a wet Vax to extract the soiled solution from the floor.  Rinse thoroughly with clean water to make sure the floor is neutralised of any chemicals. In normal circumstances allow 24 hours for the stone to dry out before sealing, a damp meter can be used to verify when the stone is dry.
Wall Tile Cleaning
Travertine Tile The best way to clean and polish Travertine wall tiles is with a hand-held polishing machine using a set of six inch Burnishing pads, we find using chemicals less effective on vertical surfaces and can lead to staining. Click here for instructions and ordering. This method is also the best way to treat the build-up of Limescale as the acidic cleaners commonly available for this will actually damage the Travertine.
Basalt Tile If the grout is in need of attention then clean the grout at this point using Tile Doctor Duo Clean which is a very effective grout cleaning product as well as treating mould. Make sure to thoroughly rinse the tiles after using Duo Clean to remove any trace of chemicals otherwise it may impact the sealer when it is applied.
Sealing Travertine Tiles
Travertine Tile  When the tiles are fully dry apply either one coat of Tile Doctor Colour Grow to enhance the natural colours of darker Travertine’s. If however you area sealing a white or off-white Travertine and you not wish to darken the stone apply a single coat of Tile Doctor Ultra-Seal which provides a natural look finish. A second coat of sealer may be required if the stone is very porous.
Water testing a sealed Travertine floor - photo courtesy of the Lincolnshire Tile Doctor
Using water to test the seal on a Travertine floor tile
Travertine Tile For architecturally specified sealers we recommend Tile Doctor Pro-Seal which is a water based impregnating sealer suitable for all types of honed stone including Travertine.
Regular Maintenance of Travertine
Travertine Tile For regular cleaning use a sealer friendly cleaning product such as Tile Doctor Stone Soap which has been especially formulated for the regular cleaning of Sealed Stone and Tile surfaces keeping them fresh.
Travertine Tile If you have applied a burnishing pad system it makes it much easier to keep these tiles clean by using a No. 4 Green burnishing pad on the stone every two to three months depending on wear. This process will improve surface tension (which is not to be confused with the amount of sealer residing in the stone), thereby tightening the pores in the stone to improve the overall appearance and finish of the floor.
Further Reading: For many more examples and photographs of of Travertine cleaning and sealing activities carried out by UK Tile Doctors please visit http://Travertine.tilecleaning.co.uk
Recommend Travertine Cleaning Products
 4 Inch Diamond Wet and Dry Polishing Pad - Step 3
4 inch diamond wet and dry polishing pad, step 3 of 3, manufactured to fit a hand held Flex Machine and designed to produce a high-quality shine on polished stone including Granite, Limestone, Marble, and Travertine.
£10.00
 4 Inch Diamond Wet and Dry Polishing Pad - Step 2
4 inch diamond wet and dry polishing pad, step 2 of 3, manufactured to fit a hand held Flex Machine and designed to produce a high-quality shine on polished stone including Granite, Limestone, Marble, and Travertine.
£10.00
 4 Inch Diamond Wet and Dry Polishing Pad - Step 1
4 inch diamond wet and dry polishing pad, step 1 of 3, manufactured to fit a hand held Flex Machine and designed to produce a high-quality shine on polished stone including Granite, Limestone, Marble, and Travertine.
£10.00
Tile Doctor Stone Soap 1 Litre
£14.40
 6 inch Set of four Burnishing Pads inc  No 1,2,3 and 4
17 Inch  3500-Grit Very Fine No.4 Burnishing Pad
Tile Doctor Shine Powder 1kg Tub
Tile Doctor High Shine Crystallising Powder adds a Very High Shine to Limestone, Marble, Polished Concrete, Terrazzo and Travertine.
Tile Doctor Reduxa 750ml
Reduxa is an effective ready to use cleaner designed to remove acid stains from calcareous stones. Will remove or quite visibly lighten stains on stone.
£15.80
Tile Doctor Pro-Seal Premium Sealer 1 Litre
£39.20
£36.68
All the information you need to be able to clean and maintain Travertine floor and wall tiles including polishing.
