£11.88
Tile Doctor Products >
Stone Burnishing
![]() Made with industrial diamonds and available in different sizes and grits, burnishing pads are ideal for restoring the appearance of polished stone walls and floors. Uses:
DemonstrationMethod of Application:
Effortlessly clean away stubborn marks from tiles with our multi-surface 17-inch cleaning pad, its especially useful for removing remants from burnishing pads. No chemicals required, simply apply to the floor with water.
£39.00
Effortlessly clean away stubborn marks from tiles with our multi-surface cleaning sponge. It quickly removes polishing residues, stains, and everyday scuffs from most surfaces — no chemicals required. Simply wet and wipe for instant results.
£5.16
4 inch diamond wet and dry polishing pad, step 3 of 3, manufactured to fit a hand held Flex Machine and designed to produce a high-quality shine on polished stone including Granite, Limestone, Marble, and Travertine.
£10.00
4 inch diamond wet and dry polishing pad, step 2 of 3, manufactured to fit a hand held Flex Machine and designed to produce a high-quality shine on polished stone including Granite, Limestone, Marble, and Travertine.
£10.00
4 inch diamond wet and dry polishing pad, step 1 of 3, manufactured to fit a hand held Flex Machine and designed to produce a high-quality shine on polished stone including Granite, Limestone, Marble, and Travertine.
£10.00
17 Inch Mega 240-Grit Carborundum Silicone Carbide Brush- Call for details - Please note these pads need retrofitting.
£195.00
17 Inch Mega 120-Grit Carborundum Silicone Carbide Brush- Call for details - Please note these pads need retrofitting.
£195.00
17 Inch Mega 60-Grit Carborundum Silicone Carbide Brush- Call for details - Please note these pads need retrofitting.
£195.00
2nd step Polishing, to smooth down rough surface, ready for final polishing, clean grout lines after using this pad.Use only Water.
1st step polishing, to grind off ingrained dirt and worn surface, use only with water.
£50.00
Coarse Burnishing pad for the removal of sealers and resurfacing of scratched surfaces, use only with water.
£50.00
