![](images/blank.gif) |
TILE DOCTOR ® Stone Soap
Aftercare Stone Cleaner |
![Tile Doctor Stone Soap - Effective PH neutral universal cleaner](images/shop/Tile-Doctor-Stone-Soap-1Litre.jpg) |
Tile Doctor Stone Soap is an after care cleaner for natural stone tiles (Honed or Polished) where a build up of patina is required thus protecting the existing sealer. Additionaly it's PH Neutral fomula is environmentally friendly containing no acids, alkalies or beaches, universal and suitable for most surfaces. |
Stone soap is excellent for for Light Duty cleaning on
Ceramic, Porcelain, Natural Stone, countertops and much more. Stone Soap is Biodegradable and 100% Organic for safe use for everyday cleaning and maintenance; especially formulated for use on Marble, Limestone, Travertine and most natural Stone surfaces, also suitable or Ceramic, Glass, Plastic and Enamel surfaces. |
Apply directly to the surface with a mop or sponge , allow to stand for approximately 2-3 minutes before wiping off or vaxing up, on heavier Contaminated surfaces agitate with a stiff brush before rinsing away.
Diltution Ratios
- Heavy duty cleaning - Diltue 1 to 5 with hot/warm or cold water.
- General cleaning and sanitizing - Diltue 1 to 10 with hot/warm or cold water.
- Maintenance cleaning - Diltue 1 to 100 with hot/warm water or cold water.
Ceramic & Porcelain
Granite
Marble
Travertine
![](images/shop/basketclr.jpg) |
1 litre bottle £12.99 each. Postage & Packing £7.50 (Incl.VAT) for 1 item, £10 (Incl.VAT) for two or more items.
♦ Avoid direct contact with the substance. Ensure there is sufficient ventilation of the area.
♦ Avoid the formation or spread of mists in the air.
♦ Store in cool, well ventilated area. Keep container tightly closed.
PLEASE NOTE: It is the Users responsibility to ascertain the suitability and safety of this product thus assuming all liability and risk thereof. It is advised that care is taken whilst using this product where there are sensitive surfaces, in cases of doubt always test the action of this product in an inconspicuous area first. |
♦ Gloves and protective glasses should be worn during application |
IF INGESTED: | Wash out mouth with water. Do not induce vomiting. If conscious, give half a litre of water to drink immediately. Consult a doctor. |
SKIN CONTACT: | Remove all contaminated clothes and footwear immediately unless stuck to skin. Wash immediately with plenty of soap and water. |
EYE CONTACT: | Bathe the eye with running water for 15 minutes. Transfer to hospital for specialist examination. |
INHALATION: | Remove casualty from exposure ensuring one's own safety whilst doing so. |
